No rear interior light - what and how to fit?
- markyp2000
- Visitor
Tadpole wrote:
Gromit wrote: I have one of these,
Ebay item 280992589897
Wired into the interior circuit so can come on via door switch or via a switch - simples)
I did read a thread someone had installed a ‘door switch’ in the lower left of the rear panel.
I noted mine has a blanking grommet is this the way yours is operated?
i just used a standed jimny door switch in the rear of mine and then a stick on bit of plastic from b&q cos my rear door dont shat as it should as its bent
- Licksan
- Visitor
I see there is a recessed rectangular area in the roof lining on the passenger side. Is that where they intended to factory fit a rear light? Was an interior light in the back an option?
I plan to fit some type of LED based lighting maybe with bracket off the rear grab handle mounts but want it hooked up to come on when opening the boot door.
- JerseyJimny
- Visitor
Not expecting much for 99p each but hey ho! Worth ago
Planning on wireing up to the original interior light
Also found these... Going to use them as map reading lights as the Red dosnt mess up your night vision or dassle other road users
And hook them up to this to finnish off things nicely!
- Raithrover
- Visitor
ZookFastback wrote: Easiest simplest solution is to use one of those magnetic 24+3 led torch-type lamps. They run forever on a couple of AA batteries and you can take it out when required for other uses.
This sort I was thinking of...
Magnet on the back, clip as well. Only about $6 inc batteries
Same concept/idea but used sticky back velcro. Allows me to attach lights in a number of different places depending on what I am doing.
