Newbie wanting help
- hiandlow
30 Sep 2012 10:14 #49126
by hiandlow
Newbie wanting help was created by hiandlow
I wonder if anyone can help and shed some light on a problem I have with my jimmy it's on a 03 plate done about 65000 so not huge amount of milage. When it idles from cold it's fine when it idles from hot it's fine but just when the engine starts to get warm the idles drop like it's going to stall it's been into Suzuki four times now and they still can't find out what's wrong with it please help thanks Darren
- markyp2000
30 Sep 2012 10:57 #49130
by markyp2000
Replied by markyp2000 on topic Newbie wanting help
so what have suzuki replaced on it
- hiandlow
30 Sep 2012 11:28 #49132
by hiandlow
Replied by hiandlow on topic Newbie wanting help
Yea would help if I put that info in they changed idle control valve and air flow valve on exhaust I think the last one is right weather it called that or not but it was some sort of valve on exhaust and that's it so far to the joy of £500 quid and problem not sorted
- markyp2000
30 Sep 2012 14:38 #49151
by markyp2000
air flow valve on the exhaust? or was it a o2/lamdba/oxygen sensor have you changer the coolent temperature sender i think its a 4/3 wire sensor that goes the the dash and to the ecu the ecu side of the switch may be faulty
- hiandlow
30 Sep 2012 16:39 #49176
by hiandlow
Ok thanks will give these ideas ago cheers
