gearbox leak
  • tenbob
29 Sep 2012 18:02 #49097 by tenbob
gearbox leak was created by tenbob
hi just noticed a leak from my jinmy gearbox.after a clean down a closer inspection it seems to be coming from the rear of the gearbox where the propshaft goes into.any of you lads give me your opinion on this leak and is there any links how to remove th prop from the gear box im suspecting it could be a seal?? thanks
29 Sep 2012 22:17 #49113 by j999pre
Replied by j999pre on topic gearbox leak
Unbolt 4 bolts from prop. Pull prop out. Remove seal. Replace seal. Refit prop. Top up any oil lost our better still do a gbox oil change check condition of prop when out. Inspect uj and shiny bit that mates with oil seal
Grey pick up Jimny
  • tenbob
30 Sep 2012 10:55 #49129 by tenbob
Replied by tenbob on topic gearbox leak
thanks fella didnt think it would be that simple will crack on.
  • gilburton
30 Sep 2012 13:28 - 30 Sep 2012 13:35 #49142 by gilburton
Replied by gilburton on topic gearbox leak
I don't think it's that simple. Suzuki quote 2.7 hrs to do the job. I had mine replaced cheaply by someone local and he only took 1 3/4 hrs??
Problem is it's still leaking. I've had a look and I think you can get the prop out without removing the gearbox gear linkage support bracket BUT you can't really see the seal when you are putting the prop back in.
I suspect the bracket and exhaust might have to be removed as well? 08 VVT
Possibly this is the reason mine is still leaking eg damage when putting prop back??
Anyone know if there is a special technique to avoid damage to the seal??
It's got a double lip and I just wondered if you had to insert it then pull back out slightly to allow the outer lip to settle??
Also there is some grease around the inside of the seal from the manufacturer. I assume you are supposed to spread this around the sealing edge and prop before fitting?
Just as a matter of interest the prop looks fairly new(no rust like the others) which would suggest to me that it may have been changed before under warranty. I know there have been a few leaky seals changed on low mileage cars.
Any way of finding out??
Last edit: 30 Sep 2012 13:35 by gilburton.
30 Sep 2012 17:20 #49183 by j999pre
gilburton wrote: I don't think it's that simple. Suzuki quote 2.7 hrs to do the job. I had mine replaced cheaply by someone local and he only took 1 3/4 hrs??
Well that is how I did mine plus it doesn't leak
Grey pick up Jimny
Time to create page: 0.162 seconds
