Jimny swap engine
- panosd
27 Sep 2012 12:52 #48970
by panosd
Replied by panosd on topic Jimny swap engine
Hello, there are a lot of options in changing engine for europe.
1) There must be a car like yours coming from the factory with the engine you want to install.
ex. a factory jimny with a 1.6 lt engine in order to make the upgrade to yours from 1.3 to 1.6 lt.
2) There must be someone else that has made before you the same mod. with the one you want to do
so he has done all the payper work and testing, and has taken permision for that.
3) You are allowed to make only a 30% upgrade to the cc engine capacity
4) Also you can start to make it from the start by your own and it will be charged as a prototype but
you will have to pass all the test that a new prototype car has to pass in order to take clearence to go
on the streets.
The most people who swap engines are not declaring it. If you have a m13 vvt or no vvt you have no
problem because the m16 or m18 are exactly the same engines from outside.
on the streets.
- goatboy
27 Sep 2012 13:26 #48973
by goatboy
No I haven't but every car in the UK has a V5 registration document. It just gets updated with the new engine details, its not a special document.
But as Panosd says its a very different issue in the rest of Europe.
Replied by goatboy on topic Jimny swap engine
minare wrote: did you do this change? go you have this document?
thanks
Guy
- minare
27 Sep 2012 14:16 #48975
by minare
Replied by minare on topic Jimny swap engine
Hey Goatboy,
i can see this, you right, therefore i nee to do homework so i will have answer for any excuse them have
- minare
01 Oct 2012 16:54 #49266
by minare
Hey all,
in follow to panosd,
can someone send or know who did these tests and have permision for jimny with 1.6 vvt engine, mine is 2009, 1.3 vvt
this could be a BIG help
thank you all
Guy
thank you all
Guy
- panosd
01 Oct 2012 18:46 #49279
by panosd
All people i know haven't declaire the engine swap.
The m13 is the same shape as the m16 and m18.
- minare
03 Oct 2012 07:55 #49370
by minare
correct me if i wrong,
i guess that it writen on the engine block (as i saw on the G13A), the model number M16A, is it right? or there is no sign apart the engine number (here we must have an engine number apart, most of the cases it comes from the factory with this number).
