my driver sides spring hits chassis
- suzuki jimny fella
14 years 1 month ago #48728
by suzuki jimny fella
my driver sides spring hits chassis was created by suzuki jimny fella
hi guys has anyone had this problem on there jimjam its when you flex it bows a bit an catch's the chassis as there is a bit of folded steel there has any one got that on there jimnys
has any one got pics of there spings on flex do they bow
got caster corrected arms i think panhard bushes are gone will try and get pics
- myers647
14 years 1 month ago #48732
by myers647
Replied by myers647 on topic my driver sides spring hits chassis
Hi mate Im not sure if mines doing the same but there is a problem when I go over a bump or as you say when the springs flex it makes a loud noise like a spring hitting something so im not thinking thinking the same.Have you got any marks where you think its hitting??
Thanks
James
Thanks
James
14 years 1 month ago #48735
Replied by suzuki jimny fella on topic my driver sides spring hits chassis
yes there are marks there mate and when i drop in to boom holes or similar thing it make a noise what you guys recon
are the coils suppose to bow a bit when under compression on flex
14 years 1 month ago #48736
will get pics up for you have you guys go any when on flex
- Smoggy
14 years 1 month ago #48744
by Smoggy
Replied by Smoggy on topic my driver sides spring hits chassis
I have welded some steel blocks together to mount onto the axle where the rubber bumpstops normally touch to limit the spring travel.
14 years 1 month ago #48745
have you got pics what lift have you got mate there is some thing welded to the chassis only on drivers side and thats what my coil hits
Time to create page: 0.083 seconds
