Fix one problem another shows us!
- ne-crock
18 Sep 2012 17:41 #48313
by ne-crock
Fix one problem another shows us! was created by ne-crock
So fixed my gearbox problem took if for a spin to make sure,
And now occasionally my 4wd light does not come on when selected, even when the light comes on i hear no hubs locking, but does not flash to indicate a problem,
Anyone any ideas i think i may just switch to manual hubs but prefer a cheap fix to an expensive one
- Johnniehec
- Thank you received: 56
18 Sep 2012 18:53 #48323
by Johnniehec
Replied by Johnniehec on topic Fix one problem another shows us!
Maybe the hubs are stuck locked and that's why you can't hear them locking when you select 4wd?
one of mine was stuck unlocked, stripped them down and one had a bit of rust in it ( I'd run on an event a while before with one of the rubber pipes pulled off the hub so moisture must have got in then) cleaned them both up and re greased them and they've been OK since.
john.
john.
Time to create page: 0.474 seconds
