Shock rubbing against Panhard
  • VAXXi
16 Sep 2012 19:45 #48216 by VAXXi
Shock rubbing against Panhard was created by VAXXi
Before mounting the rear shock brackets from Martin, the right shock was rubbing lightly against the Panhard rod:
[IMG
[IMG
After mounting the brackets, it's rubbing much harder and the shock body is well "shaved" down do bare metal:
[IMG
Shocks are Pro Comp ES1000. What's the solution ? Panhard relocation bracket such as the one below ?
Adjustable Panhard ? more fiddling with the brackets ?
  • markyp2000
16 Sep 2012 21:42 - 16 Sep 2012 21:45 #48222 by markyp2000
Replied by markyp2000 on topic Shock rubbing against Panhard
first thing i would do is aline that shock bracket so it inline with the shock and not pulling the bushes also what is the diameter of the shock and do you have any washers on the axle side of the shock bracket
what lift do you have you may need correction arms to roll the axle back (diff down at the prop end )and then it may clear
Last edit: 16 Sep 2012 21:45 by markyp2000.
  • VAXXi
17 Sep 2012 08:02 #48238 by VAXXi
Replied by VAXXi on topic Shock rubbing against Panhard
You mean to turn the bracket counter-clockwise a little, correct ?
I haven't checked the shock diameter yet, will do that. There aren't too many washers axle-side (1 or 2 if I remember correctly), the shock wouldn't fit at all with too many washers.
The car has a 2" suspension lift and a 1" body lift. Shouldn't have to correct it, especially since it's at the rear end...
  • blakey2000
17 Sep 2012 10:59 #48243 by blakey2000
Replied by blakey2000 on topic Shock rubbing against Panhard
VAXXi wrote: You mean to turn the bracket counter-clockwise a little, correct ?
just because its at the back doesn't mean the castor cant be out. its only more necessary on the front as it is a big cause of wobble (like a shopping cart wheels) if its out and the rear doesn't steer so its not usually needed. but id say that's what your problem is the axle has tipped pushing your shock mounts further back so they are closer to the pan hard. adding the extra bits of metal of the relocating bracket has just made then further out so now they really hit.
17 Sep 2012 11:25 #48246 by mlines
Also, if it is one of my current brackets these have the holes offset from the centre deliberately so that you can adjust the shock position by turning the bracket through 180 degrees.
  • VAXXi
17 Sep 2012 14:12 #48250 by VAXXi
Aaaha. Got it. So I'll try removing the washers and turning the bracket around. I'll update once it's done.
Thank you guys.
Time to create page: 0.095 seconds
