Thermostat hiding place
  • Nelson83
15 Sep 2012 18:29 #48156 by Nelson83
Thermostat hiding place was created by Nelson83
Can anybody point me in the hiding place of the thermostat on a 52 plate? I think mines given up the ghost as ive overheated twice lately. Ive reversed flushed the rad, and it seems ok at the moment, but am going to replace the rad cap and the thermostat as a priority job. A diagram or picture of the location would be great!! :-)
cheers
  • Skinhead
15 Sep 2012 18:54 #48157 by Skinhead
Replied by Skinhead on topic Thermostat hiding place
Follow your bottom radiator pipe to the engine and it should be in there. You might have to take the alternator off to get to it.
  • markyp2000
15 Sep 2012 19:19 #48161 by markyp2000
Replied by markyp2000 on topic Thermostat hiding place
what engine is it is it a single cam with a cam belt or twin cam with a timing chain if it a single follow the top hose to the engine and undo the to 12mm bolts and its in there as for the twin cam i dont no hope this helps
  • Keefe
15 Sep 2012 19:24 #48162 by Keefe
Replied by Keefe on topic Thermostat hiding place
If it's the M13a engine, it's to the front right of the engine, I believe.
Reading the workshop manual, you have to remove the inlet manifold to get at it.
  • markyp2000
15 Sep 2012 19:28 #48164 by markyp2000
thats the twin cam just thought id add that just incase any one else reads this and he dont no the differents
  • Nelson83
19 Sep 2012 09:06 #48344 by Nelson83
Replied by Nelson83 on topic Thermostat hiding place
Ive got the M13A engine - i had to wiat untila day evening and then assembled my kit and headed out. After an hour and half, i gave up and went to my local garage and booked it in. The only way i could see to get it out, was to remove the throttle and carb assembly and the mainfold :-@ something i didnt want to do of an evening
Luckily for the garage had it in the next day and i thought it would be a quick job (so did the garage). I gave them the replacement thermostat, and left them to it. I had a call later to say that theyd got the stat out, and the new one was wrong! So they called for a replacement, which turned out to be wrong, and the next one was wrong, and the next!!!! So 4 stats later theyre still waiting for a replacement stat!!
I just wonder whoever decided to put the stat there.................. why??!!! :evil:
Time to create page: 1.581 seconds
