Something clogged?
  • Ngaire
14 Sep 2012 15:18 #48118 by Ngaire
Something clogged? was created by Ngaire
I have a 1999 Jimny, I have owned this car for about a year, it was a little slow when I purchased it, but now it seams to be getting worse. When the car is cold the engine doesn't get above 2000rpm when the throttle is all the way down for the first few seconds. After a little while the revs get higher as if something has come unblocked and the car will start to move faster. 50% of the time the car will lose all power if I have stopped to make a turn, it will only do a max of 20km/ph, this is obviously quiet scarey!
I have taken the car to three separate mechanics, I have changed the air and oil filters, ran compression tests, changed the caddy, disconnected and reconnected the battery used enjector cleaning fluid. Unfortunately there aren't any Suzuki specialists nearby, but if anyone has any ideas about what is wrong with my baby it would be greatly appreciated.
Also I often have trouble getting it out of 4wd mode and blue/grey smoke comes out of the exhaust when I start it.
Thanks again!
  • markyp2000
14 Sep 2012 17:12 #48120 by markyp2000
Replied by markyp2000 on topic Something clogged?
when its reved see how much gases are coming out the exhaust it may have a blocked cat then remove the cat and see if it revs better
jimnys all puff out some smoke on start up it can be sorted but depends how much you wanna spend
as for the 4x4 is it a button 4x4 of a leaver system
14 Sep 2012 19:49 #48127 by facade
Replied by facade on topic Something clogged?
Agreed, blocked catalyst.
16 Sep 2012 12:08 #48186 by mlines
Replied by mlines on topic Something clogged?
Ngaire wrote: Also I often have trouble getting it out of 4wd mode!
Agreed catalyst, but also the inevitable question (sorry for asking it) but your not running in 4WD mode on the road are you?
  • Ngaire
16 Sep 2012 23:10 #48229 by Ngaire
Replied by Ngaire on topic Something clogged?
I've actually changed the catalyst a while ago, another expensive procedure, and the thing is still really slow. Does anyone know about an auto choke or some kind of computer that needs resetting?
4wd is a small press in gear stick, it takes brute force to get it out of 4wd mode. I haven't been driving on the roads like this :lol:
