Suspension Bolts
  • blakey2000
14 years 2 months ago #47955 by blakey2000
Suspension Bolts was created by blakey2000
Hi does anyone know what size and thread all the suspension bolts are.
size and thread of,
The Radius Arm Bolts,
Shock Bolts
Panhard bolts
Swaybar bolts
As i want to put new either SS bolts in or Tinned Steel bolts as mine are rusted and iv stripped a few so they need replacing anyway
Cheers, Blake
  • polaarbear
14 years 2 months ago #47957 by polaarbear
Replied by polaarbear on topic Suspension Bolts
Hello,
You can get the radius arm bolts, front and rear shock bolts, and panhard bolts from the BigJimny shop. It also tells you the size of each bolt.
For the sway bar, there aren't bolts you can replace. Instead you have to change the drop links.
Josh
  • blakey2000
14 years 2 months ago #47959 by blakey2000
Replied by blakey2000 on topic Suspension Bolts
polaarbear wrote: Hello,
Josh
sorry meant the bolts that hold the brackets for the swaybar to hold it to the chassis
  • blakey2000
14 years 2 months ago #47964 by blakey2000
iv had a look on the bigjimny shop it just says metric fine. there are 3 types of metric fine threads is it 1 1.25 or 1.5 ?
  • markyp2000
14 years 2 months ago - 14 years 2 months ago #47977 by markyp2000
Replied by markyp2000 on topic Suspension Bolts
m12 x1.25 trailing arm to axle same for the trailing arm to chassis front & rear shock absorber lower bolt is the same but i think there are to size lenth in the rear and i belive the panard rod bolts are aswell
antiroll bar or sway bar is i think m8 or m10 x 1.25 are that 12mm or 14mm heads on them
but correct me if in wrong
Last edit: 14 years 2 months ago by markyp2000.
  • blakey2000
14 years 2 months ago #48017 by blakey2000
markyp2000 wrote: m12 x1.25 trailing arm to axle same for the trailing arm to chassis front & rear shock absorber lower bolt is the same but i think there are to size lenth in the rear and i belive the panard rod bolts are aswell
alright cheers, Thanks for that.
Time to create page: 0.094 seconds
