4wd vacuum system - need info / help
  • jjc0424
10 Sep 2012 16:32 #47865 by jjc0424
4wd vacuum system - need info / help was created by jjc0424
Hi , as above got a question on the 4wd vacuum system on my jimny (06 plate) I am thinking about changing to manual locking hubs but not sure how it works 100%
I understand once manual locking hubs are fitted you turn them physically to lock them in which as far as I understand means that's you from 2wd to 4wd high, correct ?
Here's my next question if above is correct how do you change from 4wd to 4 low??
Take it you don't just push the bottom because the vacuum hoses have been disconnected to fit the manual locking hubs ??
Any help would be great
Jamie
  • markyp2000
10 Sep 2012 17:12 #47867 by markyp2000
Replied by markyp2000 on topic 4wd vacuum system - need info / help
use your 4x4 leaver in the same way instead of the car locking the hubs you have to get out and turn them
  • jjc0424
10 Sep 2012 17:24 #47868 by jjc0424
Replied by jjc0424 on topic 4wd vacuum system - need info / help
Hi I don't have the lever its the push buttons I have in my jimny
  • Paul4x4
10 Sep 2012 17:32 - 10 Sep 2012 17:33 #47869 by Paul4x4
Replied by Paul4x4 on topic 4wd vacuum system - need info / help
You just push the 4wd buttons like you're used to do after those vacuum hoses are plugged. Only difference is that you have to go out of the truck, and manually turn the hubs into lock position. If you don't go and lock them, it won't go into 4wd no matter what button you push, because the power is not transfered to the front wheels as long as the hubs are open.
Last edit: 10 Sep 2012 17:33 by Paul4x4.
  • markyp2000
10 Sep 2012 17:50 #47870 by markyp2000
yer what paul said but you never said it was a button one lol well thats how it works if you have a leaver type transferbox
  • jjc0424
10 Sep 2012 18:06 #47871 by jjc0424
Ok thanks , just making sure before a actually buy them
