Granada brake calipers
  • Smoggy
07 Sep 2012 21:04 #47766 by Smoggy
Granada brake calipers was created by Smoggy
I know this is not Jimny stock parts, but I have Ford granada discs to replace my jimny rear drums. My problem is this, I have removed the rear calipers to repipe them and cant remember which connection to use on the caliper with 2 connections that goes to the other caliper. In other words does it matter if I use the top or bottom output to go across the rear axle to the other caliper with one input.
I can post pics of the calipers if needed but I dont think it will help much.
  • Dave c
07 Sep 2012 21:32 #47767 by Dave c
Replied by Dave c on topic Granada brake calipers
think you should put a pipe to each caliper from the tee piece pipe wants to go in on the lowest point and bleed nipple at the highest point i have E36 beemer calipers on mine ok not same axles but principle the same
  • markyp2000
07 Sep 2012 22:50 #47773 by markyp2000
Replied by markyp2000 on topic Granada brake calipers
i got a muddyzook disc conversion using rover 25 calipers on mine i used a T bit if you have the tooling which you do then think about it for a bit then go for it wont take more than an hour i bet
or are you trying to plum it in like the jimny brakes was in that case in at the bottom out at the top on one side then in at the bottom and blead nipple at the top of the other one
a pic would be good i like pics of othe peoples mods lol
Time to create page: 0.066 seconds
