rock lobster transfer box problem
  • George147
04 Sep 2012 20:41 #47487 by George147
rock lobster transfer box problem was created by George147
I have a problem my rocklobster trans box- keeps jumping out of gear/grating in 2 wheel drive and H4 when any load put on it L4 is not as bad. I have stripped and rebuilt 3 times now checking everything but cant get it to work right. All bearings and seals are new. Selector dogs and selector ring only have minimal wear and selector mechanism functions correctly with all springs and 3 balls in the right places. don't know if anyone has had the same problem?. I think I need someone with more experience of building these boxes to take a look at it for me any sujestions?
  • TomDK
04 Sep 2012 20:57 #47488 by TomDK
Replied by TomDK on topic rock lobster transfer box problem
George147 wrote: I have a problem my rocklobster trans box- keeps jumping out of gear/grating in 2 wheel drive and H4 when any load put on it L4 is not as bad. I have stripped and rebuilt 3 times now checking everything but cant get it to work right. All bearings and seals are new. Selector dogs and selector ring only have minimal wear and selector mechanism functions correctly with all springs and 3 balls in the right places. don't know if anyone has had the same problem?. I think I need someone with more experience of building these boxes to take a look at it for me any sujestions?
Since it's a rocklobster box. Why not try contacting Rockwatt. He should be able to help :-)
04 Sep 2012 20:58 #47490 by mlines
Are the mounts ok and is the selector not fouling on the transmission tunnel?
  • George147
04 Sep 2012 21:39 #47493 by George147
Replied by George147 on topic rock lobster transfer box problem
Mounts are new ORA and lever does not make any contact with transmission tunnel - wish it did my life would be much easier!
  • Rockwatt
06 Sep 2012 10:43 #47625 by Rockwatt
Replied by Rockwatt on topic rock lobster transfer box problem
No prob send it up and I'll have a look for you.
  • g187eev
06 Sep 2012 15:39 #47630 by g187eev
Replied by g187eev on topic rock lobster transfer box problem
check the shifter seat at the base of the lever also... easily overlooked.
We keep factory Suzuki shifter seats on the shelf, along with full gasket/seal kits which might be of use when you finally suss it...
RB
Time to create page: 0.391 seconds
