Belt adjuster
- Gromit
01 Sep 2012 06:39 #47256
by Gromit
Belt adjuster was created by Gromit
Is the steering pump belt adjuster/pulley supposed to be spring loaded as mine isn't.
So how do I get enough tension in the belt whilst tightening the 12 mm adjuster nut, is it just a matter of pressing down hard on the pulley whilst tightening the nut ?
01 Sep 2012 08:23 #47258
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Belt adjuster
There is a hex hole in the pulley. Pop an ashen key in to apply tension. Its a sort of can adjuster tensioner. This is assuming you have the m13a engine
Grey pick up Jimny
- markyp2000
01 Sep 2012 12:03 #47264
by markyp2000
Replied by markyp2000 on topic Belt adjuster
what engine do you have i have a single cam engine all i do is losen the nut in the middle of the tensioner pully (14mm?) and tighten the 12mm nut at the top that inturn pulls up the tensioner pully and then retighten the tensioner pully nut once the belt is tight enough if yours is a twin cam than i have no idear hope this helps
- Gromit
01 Sep 2012 12:18 #47265
by Gromit
Replied by Gromit on topic Belt adjuster
Yep mine is twin cam.
I have done it but note that the belt 4PK850 in the books at the auto factors is wrong and too short !. The correct belt is 4PK890 (48356), and the allen key to tension the pulley a 10mm.
I found that the best thing to do is get the pulley pinch nut
reasonably tightish then use a long 10mm allen key to set the tension and then nip up the pinch nut and the other nut .
