4" LIFT
- myers647
30 Aug 2012 20:23 #47174
by myers647
4" LIFT was created by myers647
Hi this will probably have been answered before but if I lift my Jimny up to 4" do I need a prop spacer.
I have 3" springs at the minute and I have some 1" spacers to go on top.
I have adjustable panhard rods as well will these need to be adjusted if so how to.
Thanks
James
Thanks
James
- supergaz
30 Aug 2012 20:51 - 30 Aug 2012 20:52 #47178
by supergaz
Replied by supergaz on topic 4" LIFT
Its only caster correction that pulls the prop away requiring a spacer. With caster correction bushes, you may find it drives like poop with 4" of lift. Ideally you want caster corrected front arms, not bushes with 4" lift.
Last edit: 30 Aug 2012 20:52 by supergaz.
- myers647
30 Aug 2012 20:53 #47179
by myers647
Replied by myers647 on topic 4" LIFT
Or I didnt think it would make a difference to the drive if I already have castor corrected bushes I thought that as the whole point of them????
- supergaz
30 Aug 2012 20:57 #47180
by supergaz
Bushes only give the correction for 2" lift. B4V did some for a 3" lift but were made of hard poly and were not ideal for flex.
Once over 2" you ideally want caster corrected arms, also the standard suzuki arms are made of cheese, mine were all bent.
Time to create page: 0.159 seconds
