Battery check on
- charlanga
27 Aug 2012 14:59 #46893
by charlanga
Battery check on was created by charlanga
Hi guys,
This morning while driving to my job, the battery check light turned on, the battery is almost new(not even 3 months), all cables all right, could it be the alternator?
Some friends already suggested to check the battery's voltage.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
- reaper
27 Aug 2012 15:04 #46894
by reaper
Replied by reaper on topic Battery check on
Check battery 12-13 v ish then check with engine running 13-15 v ish if not then alternator is the culprit
27 Aug 2012 17:07 #46901
by facade
Replied by facade on topic Battery check on
You have checked the drive belt?
If the alternator fails, and the little red light glows faster as the engine speed increases, keep the revs down, or the bulb will blow.
- charlanga
27 Aug 2012 21:39 #46932
by charlanga
Replied by charlanga on topic Battery check on
Thaks for your advices!
I'm going to check it in a few minutes.
Time to create page: 0.168 seconds
