Retrofit Remote Central Locking Question
- markyp2000
25 Aug 2012 17:43 #46770
by markyp2000
Replied by markyp2000 on topic Retrofit Remote Central Locking Question
dont no the colour put it left and see what one flashes a live and right for the other
- Jimnyash
27 Aug 2012 11:14 #46864
by Jimnyash
Replied by Jimnyash on topic Retrofit Remote Central Locking Question
OK.
Spent too much time on it this morning trying to get this to work.
I found the indicator cables from the stalk (had to find them on the connector at the bottom as getting to the stalk base was a swine).
I checked them with the multimeter and got a signal when the indicators were on. I also checked the cables from the remote locking box and that was putting out a signal too.
Put them together ---- nothing.
I tried running to the back of the bulbs and all that did was blow fuses.
What am I missing here? Is it something to do with negative switching or something?
27 Aug 2012 12:00 - 27 Aug 2012 12:08 #46868
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Retrofit Remote Central Locking Question
If you wire up a set of spot light on a jimny the trigger wire go on the earth side not the live side of the plug.
So maybe the your wire needs to go on the earth side of the indicator bulb.
this is how l wired my spot light.
Hope this help.
DIRTYDOGZ.
Hope this help.
DIRTYDOGZ.
2002 JLX Soft Top
Last edit: 27 Aug 2012 12:08 by dirtydogz.
The following user(s) said Thank You: Jimnyash
- Jimnyash
27 Aug 2012 12:15 #46869
by Jimnyash
I did wonder if it was something like that. Trying the earth side of the bulb just popped the central locking fuse (unless I shorted it somewhere else).
Hmmmm....
Hmmmm....
- markyp2000
27 Aug 2012 12:50 #46873
by markyp2000
is the control unit your fitting putting out a + or - feed i no the switch put a + feed but im shore it wouldnt turn to a - pulse at the bulb also check the voltage the switch puts out to what your control unit is putting out
27 Aug 2012 14:47 - 27 Aug 2012 14:48 #46889
by facade
Replied by facade on topic Retrofit Remote Central Locking Question
If it is any help
green wire/red stripe is left indicator
green wire/yellow stripe is right indicator
(the wires can be joined into at the hazard switch, column wires or anywhere in the main loom.)
The later cars use some bizarre switching at the column, and an electronic turn signal relay, that does left/right/hazard by itself.
In both cases, a live on the green wire/red stripe will put the left indicator on.
Last edit: 27 Aug 2012 14:48 by facade.
Time to create page: 0.241 seconds
