Shockers ???
  • Gromit
20 Aug 2012 17:28 #46478 by Gromit
Shockers ??? was created by Gromit
I'm I a bit thick, surely when a shocker is depressed and then released it should spring back to the exteded position, because my front ones don't :unsure:
  • chimpbikes
20 Aug 2012 17:36 #46481 by chimpbikes
Replied by chimpbikes on topic Re: Shockers ???
Is that not the springs job? The damper will stay put, it just has oil/gas in it I think.
Just my idea of the set up.
  • Paul4x4
20 Aug 2012 18:11 #46483 by Paul4x4
Replied by Paul4x4 on topic Re: Shockers ???
Gas shocks will do that, but the oil filled won't.
  • mcjimny
20 Aug 2012 21:12 #46513 by mcjimny
Replied by mcjimny on topic Re: Shockers ???
Gromit wrote: I'm I a bit thick, surely when a shocker is depressed and then released it should spring back to the exteded position, because my front ones don't :unsure:
If you've undone the bottom bolt it will sort of find its natural position, i had to fight with mine to extend them far enough while i put the bolt in, if i let go it crept back!
If they're all bolted up to the car if you bounce the corner it should go up, down, then settle.
Time to create page: 0.182 seconds
