Propshaft spacers.
- Barnyzuki
16 Aug 2012 18:35 #46273
by Barnyzuki
Propshaft spacers. was created by Barnyzuki
Hi all, I`m a lot more used to playing with SJs/Sammis and the the X-90 than I am with Jimnybobs so I need a question answering if you could.
I have (approx) 100mm lift springs to go on my Jimny, do I need propshaft spacers ?
I do already have shocks, panhard rod bracket, brake lines, etc etc to suit the lift.
Cheers for you help, in advance, Barny.
- Barnyzuki
19 Aug 2012 09:55 #46388
by Barnyzuki
Replied by Barnyzuki on topic Re: Propshaft spacers.
Wow, this must be a tricky one judging by all the replies.
I do already have spacers I can borrow from my X-90 if needs be, would have been handy to know if anyone does use spacers what size they are so I could buy them in ready
- markyp2000
19 Aug 2012 10:24 #46389
by markyp2000
Replied by markyp2000 on topic Re: Propshaft spacers.
i have a 4.5" lift and i have front and rear prop spacers i think thay are 25mm have a look at the offroad armoury site
- Thank you received: 115
19 Aug 2012 10:32 #46390
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Propshaft spacers.
I have 3inch Lifted Springs on my Jimny, but I DON'T have any prop-shaft spacers, but i do have a SJ T-case with custom made props...
I suppose, you'll just have to fit everything to find out.
Dave at B4V makes many different sizes of spacers ...
Jalapeño, IISY?
The following user(s) said Thank You: Barnyzuki
- Nobby22
19 Aug 2012 11:10 #46391
by Nobby22
Replied by Nobby22 on topic Re: Propshaft spacers.
When i had my 3" lift with standard radius arms i had no prop spacers, didnt need them.
When i got my 3" corrected front radius arms i needed to fit a prop spacer as the arms push the front axel out. Iam fairly certain it was a 25mm one but i think it may be a 18mm one if you have a sammy box fitted.
Hope that helps.
Email ORA if you need any other help. They are very friendly and helpfull and know a thing or two about Jimny's :laugh:
Hope that helps.
- Barnyzuki
19 Aug 2012 12:30 #46393
by Barnyzuki
Than you very much for that fellers, I was begining to think no-one liked me
Looks like I`ll be fitting the Lada springs and see what happens from there
Time to create page: 0.173 seconds
