iddle issues
  • fedor42
14 Aug 2012 07:18 #46151 by fedor42
iddle issues was created by fedor42
Hi, I´m from Costa Rica, have a 2005 petrol Jimny, need help because I have some trouble...
When I have lights on and stop iddle is goin down... from 900 rpm to 500 rpm... then the car move so strange...
Change everything you think: iddle valve (and sensor), filters... etc. What sensor will be bad???
Sorry for my english (I don´t speak from 10 years... I think)
Thanks for all and Pura Vida!!
  • markyp2000
14 Aug 2012 17:25 - 15 Aug 2012 16:53 #46174 by markyp2000
Replied by markyp2000 on topic Re: iddle issues
some thing is causing a drain on the eletrics have you checked the output/charge rate on the alternator your revs should drop a lottle but then come back up to normal
Last edit: 15 Aug 2012 16:53 by markyp2000.
  • 247sniper
14 Aug 2012 22:33 #46201 by 247sniper
Replied by 247sniper on topic Re: iddle issues
Have a look at the stepper motor. ;)
  • fedor42
17 Aug 2012 00:11 #46300 by fedor42
Replied by fedor42 on topic iddle issues
Thanks never thought of these parts
this problem is driving me really mad
As I said, I changed plug wires, spark plugs, fuel filter and air filter, idle sensor ...
Now we just need to change TCP sensor, MAF and Lambda sensor (perhaps be cause of the problem of idle?)
Suzuki scanner only reads ECU (I think Hana tech or Tech 2 Bosch) in Costa Rica almost no mechanical with this tool ...
Thank you very much for your help with this I have new ideas to fix the Jimny
Pura Vida!
Time to create page: 0.142 seconds
