Oil light flicker under harsh breaking
  • markyp2000
14 Aug 2012 17:22 #46173 by markyp2000
Replied by markyp2000 on topic Re: Oil light flicker under harsh breaking
Paul4x4 wrote: It's valve stem seals that have gone bad if it puffs some blueish smoke on start up. Mine does that too, and I'm about to replace those seals when I find some time. My Jim has some 150k on the clock, which is quite a lot, so no wonder the valve stem seals are a little bit on the dead side! No other problems with the engine though, runs good, and doesn't burn oil when running.
not only could it be valve stem seals it could be the valve guides as if thay have movment in them it opens up the seal and lets oil past as it moves side to side im in the proses of carring out a rebuild on my single cam and it going from bad to worse
  • Paul4x4
14 Aug 2012 17:59 #46178 by Paul4x4
Replied by Paul4x4 on topic Re: Oil light flicker under harsh breaking
markyp2000 wrote: not only could it be valve stem seals it could be the valve guides as if thay have movment in them it opens up the seal and lets oil past as it moves side to side im in the proses of carring out a rebuild on my single cam and it going from bad to worse
That might be the case too that the guides and seals are all shot, but I don't think those guides would go bad very easily if the engine's been maintained properly, though...
BTW, how many miles there was on your engine before you started rebuilding it?
  • markyp2000
14 Aug 2012 18:15 #46180 by markyp2000
50,000 good servive history before i brought it and has only had 4 owners inc me
  • ne-crock
14 Aug 2012 18:53 #46183 by ne-crock
Replied by ne-crock on topic Re: Oil light flicker under harsh breaking
well all my service parts arrived today
(fantastic service from the big jimny shop)
so service will proceed as soon as possible put a litre of oil will see my past tomorrow most likely!
  • ne-crock
16 Aug 2012 16:51 #46269 by ne-crock
All good a serviced today, i was running low oil so was my problem,
running sweet as a nut again,
bar one issue, thermostat is stuck shut,
how hard is it to replace?
  • markyp2000
16 Aug 2012 17:02 #46270 by markyp2000
top rad hose to inlet manifold to bolts easy
