Oil light flicker under harsh breaking
  • ne-crock
13 Aug 2012 22:09 #46147 by ne-crock
Oil light flicker under harsh breaking was created by ne-crock
As title says my oil light flickers under harsh breaking more so when pointing down a hill,
I know my oil level is running a bit low, but just order new filter plugs etc so plan to service this weekend,
Engine sounds a little more tappy also,
I presume this is all due to low oil level, so if i put a litre in do you think it will survive till the weekend, i dont want to put a new oil change in to then drain to put fresh oil again come the weekend,
Also smokes a little on cold start up at first ignition then fine once running,
Any ideas?
Cheers crock
  • mcjimny
14 Aug 2012 08:15 #46152 by mcjimny
Replied by mcjimny on topic Re: Oil light flicker under harsh breaking
You've already answered your question i think, they are tappety initially, mine settles within a second of start up. Get a bit in until your change, it will also run hotter if you've not got enough in.
What colour is the smoke? Blue is oil, white is water/steam.
What sort of mileage is it and does it burn oil?
  • ne-crock
14 Aug 2012 12:23 #46158 by ne-crock
Replied by ne-crock on topic Re: Oil light flicker under harsh breaking
Yeah i thought i was right but i was asking to double check not huge in the knowledge of engines
Its the gb13 with 67k on the clock,
Its hard to tell the colour seems white to me,
Its using more oil but i cant see any leaks, no oil spill on the drive
  • mcjimny
14 Aug 2012 13:38 #46160 by mcjimny
Not sure on what those are like tbh. It could be perfectly normal and just be condensation on start up.
If its burning oil iirc thats rings but usually accompanied by a bit of blue smoke, again i'm not sure if that engine's prone to problems with the rings. One of the more experienced mechanic types will be along shortly!
  • Paul4x4
14 Aug 2012 16:04 - 14 Aug 2012 16:06 #46166 by Paul4x4
Replied by Paul4x4 on topic Re: Oil light flicker under harsh breaking
It's valve stem seals that have gone bad if it puffs some blueish smoke on start up. Mine does that too, and I'm about to replace those seals when I find some time. My Jim has some 150k on the clock, which is quite a lot, so no wonder the valve stem seals are a little bit on the dead side! No other problems with the engine though, runs good, and doesn't burn oil when running.
Last edit: 14 Aug 2012 16:06 by Paul4x4.
  • goatboy
14 Aug 2012 16:54 #46170 by goatboy
Replied by goatboy on topic Re: Oil light flicker under harsh breaking
If the oil light is flashing the oil must be really low, top it up before you do any damage even if its just cheap crap. Almost anything is better than nothing (particularly if you are changing the oil soon anyway)
Time to create page: 0.267 seconds
