Pic of Stearing shaft mod for 2 inch body lift
- oxford_bloke
14 Sep 2010 12:15 #4648
by oxford_bloke
Replied by oxford_bloke on topic Re:Pic of Stearing shaft mod for 2 inch body lift
having read all of your posts. I just wanted to clear up all these issues there are 4 high tensile bolts i know that in the picture it only looks like one. They are nylocs but not pinned but what i expect i will do now is peen the threads just to make sure. The bits 4 vits spacers do not fit a jimny i have already spoken to dave there. and cp for the washers yes they are not ideal but its cheaper than steel tube and they are a damn site better than the plastic ones that are fitted as standard.
Hope this clears things up
Tom
Tom
- Johnniehec
- Thank you received: 56
15 Sep 2010 08:26 #4666
by Johnniehec
Replied by Johnniehec on topic Re:Pic of Stearing shaft mod for 2 inch body lift
I was confused as well and was about to ask if there were four bolts in total, thanks for clearing it up Oxford_bloke. From your picture I couldn't work out how it could possibly stay tight with your bolts or the machined version pinned, threadlocked or not! Now that we know ther's four I don't see a problem, but I'm not an engineer.
John.
John.
- darthloachie
15 Sep 2010 10:11 #4668
by darthloachie
Replied by darthloachie on topic Re:Pic of Stearing shaft mod for 2 inch body lift
oxford_bloke wrote:
Sounds like a new product for Martin? :huh:
- renard38
15 Sep 2010 14:14 #4669
by renard38
Replied by renard38 on topic Re:Pic of Stearing shaft mod for 2 inch body lift
- Jamie
15 Sep 2010 16:26 #4671
by Jamie
Replied by Jamie on topic Re:Pic of Stearing shaft mod for 2 inch body lift
ooky_123 wrote:
There is far too much pressure on that bolt when turning the steering,I wonder what an insurance assessor would say in the event of a collision!!!!!!!
At least put two lock nuts on and lock it off that way!!
Jamie
If its a high tensile bolt, and the nut is thread locked, I wouldnt have an issue with that, ok, maybe U would use a solid piece of steel tube instead of the washers, but it looks ok to me
Jamie
- oxford_bloke
24 Sep 2010 09:36 #4799
by oxford_bloke
jamie there are four bolts in total, so i would like to see you try to brake 2 8mm bolts using a steering wheel, and as for threa locking i am an aircraft engineer by trade and belive it or not rotor blades are held on by 2 bolts and 2 nylocs.
Time to create page: 0.227 seconds
