Spring spacers ??
- Gromit
12 Aug 2012 08:31 #45959
by Gromit
Spring spacers ?? was created by Gromit
Ok so I"ve gone for the cheap option of fitting 2" spring spacers and shocker extenders instead of a proper lift kit but it seems to have made the front end very harsh over things like speed humps, so much so that it feels like the axle is loose !!!. Has anyone else experienced this ??
- goatboy
12 Aug 2012 12:31 #45984
by goatboy
Replied by goatboy on topic Re: Spring spacers ??
I've got 1.5 spacers and it is a bit more crashy at the front but not too bad.
Did you fit shock spacers at the front too? I didn't but I hear it makes a fair bit of difference.
- Gromit
12 Aug 2012 15:20 #45998
by Gromit
Replied by Gromit on topic Re: Spring spacers ??
Yep, fitted front shock spacers from bits4vits .
- dirtydogz
12 Aug 2012 16:16 - 12 Aug 2012 16:17 #46008
by dirtydogz
Replied by dirtydogz on topic Re: Spring spacers ??
I had the spaces that goatboy is using now on my jimny, and had the same trouble if you hit the speed hump head on, had to try hitting the hump one front wheel at a time by changing the approach angle.
Last edit: 12 Aug 2012 16:17 by dirtydogz.
- Black Toy
13 Aug 2012 20:34 - 18 Aug 2012 03:15 #46134
by Black Toy
Replied by Black Toy on topic Re: Spring spacers ??
I've been using front shock spacers for quite some time and realized they get loose easily. This can cause what you guys are complaining at (had experienced myself). Solution was to use a chemical lock (Loctite) on the shocker top bolts (pinions) to avoid any play down there. Watch out for corrected bump stops as well.
If it's Bits4Vits, i'd recommend replace bushes or keep original. Also try to keep the standard washers as the ones that are provided are flat and do not "hug" the top bushes properly! You just gonna have to open up the center a little cause the bolt (pinion) of the shock spacer is thicker than the one from the shock itself.
cheers
cheers
Last edit: 18 Aug 2012 03:15 by Black Toy.
- Tommo
16 Aug 2012 21:35 #46292
by Tommo
Replied by Tommo on topic Re: Spring spacers ??
ive got 2" blocks aswell
but still standard shocks
if any thing i think the rear end is stiffer, if over a speed bump, the front goes over confy
but the rear bounces over and its noisy
Time to create page: 0.187 seconds
