Testing a winch
- darthloachie
09 Sep 2010 10:36 #4571
by darthloachie
Testing a winch was created by darthloachie
I have a bare warn tabor winch that came with the Jimny when I bought it.
There are no solenoids with it and it is a series wound motor - three terminals on the motor housing
How can I test it to see if it works before I go to the expense of buying a solenoid box and cable?
09 Sep 2010 11:50 #4572
Replied by mlines on topic Re:Testing a winch
I assume that its actually a 4 terminal motor, is there a "Motor Ground" connection?
There are often one connection at one end of the motor "A" and two near to each other at the other end "F1" and "F2" and a motor ground underneath (opposite side of the motor to "A")
Does this sound right?
- darthloachie
09 Sep 2010 16:48 - 09 Sep 2010 16:51 #4573
by darthloachie
Replied by darthloachie on topic Re:Testing a winch
Last edit: 09 Sep 2010 16:51 by darthloachie.
09 Sep 2010 17:40 #4576
Right....
1. Connect the ground stud to the negative (black or minus) of a car battery.
2. Connect the "A" Terminal to the "F2" Terminal using a heavy duty (car jump lead cable)
3. Touch the battery positive to the "F1" Terminal and the motor will spin in one direction.
4. Remove the positive lead from "F1"
5. Move the connection that runs from "A" to "F2" and make it connect "A" and "F1".
6 Touch the battery positive to "F2", the motor will spin the in other direction.
- darthloachie
09 Sep 2010 17:42 #4577
by darthloachie
Great thanks
I'll try that
I'll try that
- darthloachie
10 Oct 2010 14:37 - 10 Oct 2010 15:09 #5059
by darthloachie
tested my winch today - moved a quarter inch then black smoke a burning smell - oh well in the scrap bin - got to buy one now
any one got one for sale??
Last edit: 10 Oct 2010 15:09 by darthloachie.
