4wd drive issues, not working.....complete novice
  • thesmi
05 Aug 2012 17:57 #45524 by thesmi
i will have a fiddle and try lifting one wheel up a time as didnt try this and see what comes of it !, just hope its some thing cheap and easy to rectify,
if this doesnt help i will order some kingpin bearing and seals etc and just strip down and rebuild atleast that way it will be better when finshed as gives a bit of a shake at 45mph then goes at just over 50mph for some reason just asuming could be this!
05 Aug 2012 18:03 #45525 by facade
thesmi wrote: even with me manually enguaging the hubs buy removing twisting it poping back in place still doesnt work so surely this must been shafts or diff
or am i wrong and it need constant air vacum from pump???
Remove black hub (6 E series bolts)
Put finger in splined hole in hub.
Wiggle finger whilst pulling outwards, middle springs up. and locks. Use finger to turn splines in hole, you cant.
Do other side.
Wipe grease off finger.
Carefully replace hubs making sure you don't dislodge inner.
put in 4wd
Jack up one front wheel, try to turn it, it should just rock from side to side.
  • thesmi
05 Aug 2012 18:14 #45528 by thesmi
Do other side.
put in 4wd
i done this and lifted the read of car with forklift (so rear wheels in air and front touching) it didnt pull so still didnt move
i think best bet is borrow a car as is nmy daily driver then just strip mine down at work
  • markyp2000
05 Aug 2012 20:00 #45535 by markyp2000
have you checked all the pipe work to the hubs it could also be a wheel bearing as there is a seal in there that is in the vacuum system on the hubs
also you could take both the locking hubs off put it in 4wd no need to have engine running turn the front prop one shaft will move one way the other may turn the opposite way
or remove both hubs put in 4wd wind in a bolt in the drivers side half shaft untill it turns the shaft and see if the othe side turns backwards if so the drive train is fine and you ither have a vacuum problem or a hub problem of just buy some sj manual hubs and be done with
  • thesmi
07 Aug 2012 16:52 #45641 by thesmi
well problem half sorted
im able to get into 4wheel drive by manually taking hub thing off and jiggling them into right bit,
i also can here the click people talk sbout but just wont engage its self
im going to have to buy some manual locking hubs
  • markyp2000
07 Aug 2012 16:55 #45643 by markyp2000
have you carryed out any of the things that have been posted up
Time to create page: 0.382 seconds
