4wd drive issues, not working.....complete novice
  • thesmi
07 Aug 2012 17:24 #45647 by thesmi
only done the putting one wheel in the air and see if it spins,
im going to just buy some manual hubs i cant be dealing with them not working!
now i know its not the diff or shafts broken it means its either the hubs the air lines so im going to have a fiddle when i get a chance,
where is best place to buy hubs i can maually lock im not going to be doing any off roading at payplay sites just for green lane farmers field golf course etc nothing serious (yet)
i found these but dont appear to be in the uk
www.automobiles.de/epages/61737168.sf/en...37168/Products/18521
07 Aug 2012 17:45 - 07 Aug 2012 17:49 #45652 by Johnniehec
Hi thesmi,
I think you confused everyone in your first post when you said you'd manually locked your hubs and it made no difference, and I think maybe you hadn't. Here's the link you need
www.bigjimny.com/index.php/forum/7-jimny...ng?limit=12&start=12
If you're going to bin the auto hubs use, or cut a piece of the rubber hose and loop it between the upper and lower connector on the back of each hub to keep the sh*t out.
Does anyone know if you loop the air hose right back at the air solenoid does it fool the 4WD flashing lamp? There's no harm leaving them permanently manually locked like this as long as you back to 2WD before you go on the road/grippy surface. All you'll do is maybe use a little bit more fuel, the old series LRs and early SJs had permanently locked hubs. If you change back to 2WD while you've lock on you may need to reverse a little to let 4WD disengage, but you sometimes need to do that when the auto hubs are working correctly anyway.
Last edit: 07 Aug 2012 17:49 by Johnniehec.
  • thesmi
07 Aug 2012 17:50 #45653 by thesmi
Johnniehec wrote: Hi thesmi,
www.bigjimny.com/index.php?option=com_co...echain&Itemid=37
i thought i had done a must have knocked it when putting it back on :blush: :blush: :blush:
your link doesnt open!
i could put a load of mastic in the hub and it would lock it and save me £££'s but would this wind up the diff! when in 2wd
07 Aug 2012 17:52 #45654 by Johnniehec
Yes it's easily done. I've just changed the link I couldn't open it either!
John.
07 Aug 2012 19:08 #45669 by facade
To stop the 4wd light flashing
either
plug the rubber pipes going from the vacuum valves under the battery to the hubs (easiest option)
or join the 2 wires together at the switch found near the vacuum valves. Then remove the vacuum pipe from the inlet manifold to the valves, and cap at the manifold end.
You shouldn't really drive around for very long with the hubs engaged in 2wd, as the plain bearing at the hub end of the driveshaft will wear out. (Landrovers have ball races and oil at this position)
  • markyp2000
08 Aug 2012 16:59 #45720 by markyp2000
at the end of the day you could be waisting your money if you was to carry out a simple vacuum pipe check on all the pipes one could be split and a bit of pipe about 4" long and all your troubles could be solved
Time to create page: 0.231 seconds
