Jimny Clutch
- Brian.SMC
05 Sep 2010 13:31 - 05 Sep 2010 13:35 #4540
by Brian.SMC
Jimny Clutch was created by Brian.SMC
Not in any way taking anything away from the great "How To"
write up but it can be done removing a fraction of what is in the wirte up.
First time doing a Jimny Clutch, this how I did it.
Remove Gear stick and the rear gearbox mount and bracket.
Removed gearbox prop
I loosened starter {top bolt a pig to get at}
Undid bellhousing bolts and clutch cable.
Slide box back about 6" and unbolted clutch.
Fitted new one put bolts in finger tight so pressure plate could slide around a bit.
Lined up roughly with my finger and slide box back in palce.
You can get a mate to move the crank with a spanner ever so slightly to help spline line up.
Tightend all the clutch blots in through the clutch cable cover.
Tape the socket on as you don't want to have to take box back out.
Refit the remaining parts.
Last edit: 05 Sep 2010 13:35 by Brian.SMC.
05 Sep 2010 16:44 #4545
by facade
Replied by facade on topic Re:Jimny Clutch
Sounds good: what socket do you tape on?
