rear radius arm bushes
14 years 3 months ago #44974
by robs5230
standard jimny - for now
rear radius arm bushes was created by robs5230
i need a couple of rear radius arm bushes on the axle end . bit of a knock on my standard bushes.
i have had a look round at the options and have a couple of questions.
1 are castor correction bushes only fitted on the front axle ?
2 how should the car be supported to remove the rear radius arms ?
many thanks
many thanks
- vitara_mad
14 years 3 months ago #44976
by vitara_mad
Replied by vitara_mad on topic Re: rear radius arm bushes
you can fit caster bushes on the rear too i did on mine & ive heard other have done it too
do 1 side at a time if you can jack it up put axel stand under chassis & take wheel off & then use jack to support the axel while you get arm off
quite often you find that the bolts have seized into the center of the bushes so you end up having to cut the bolts off & then if its a bush you was not planning on changing try to get rest of bolt out or buy new ones
14 years 3 months ago #44978
by robs5230
Replied by robs5230 on topic Re: rear radius arm bushes
thanks for that. it's going for test next week. i'll see what they pick up then order what i need. i'll order bolts too.
Time to create page: 0.071 seconds
