Rear axle play
  • 247sniper
28 Jul 2012 09:39 #45011 by 247sniper
Replied by 247sniper on topic Re: Rear axle play
I have the excact same symptom, on mine it is the back lash between the rear diff gears.
Its not that bad but it is noticable, i just live with it.
Steve.
28 Jul 2012 23:15 - 28 Jul 2012 23:17 #45039 by facade
Replied by facade on topic Re: Rear axle play
Make sure that there is enough oil in the axle, if you haven't changed it, now would be a good time, as they sometimes fill up with water, which does them a lot of no good. Low oil kills the pinion bearings, make sure the propshaft flange doesn't move up & down or sideways.
The diff on mine clonks (as you say when starting off in reverse) and if you raise one wheel and turn it by hand, it feels like all the cogs are jumping and whirring. However this is exactly the same as the diff in the garage, which was the original one that I changed because it clonked and felt like all the cogs were jumping........
Last edit: 28 Jul 2012 23:17 by facade.
Time to create page: 1.802 seconds
