Rear axle play
26 Jul 2012 06:06 #44936 by pgatensuk
Rear axle play was created by pgatensuk
Hi all,
After a year away from Jimny's I'm back with another softtop. This time a 2005.
When I pull away in first or reverse I can hear a slight 'clunk', more noticeable in reverse. I never had this sound on my old 2002 softtop. It's not bad, but is noticeable.
I stuck the car in gear and got under the car to rock it and the sound (play) is in the rear axle. All the bushes seem fine and so is the propshaft.
This car is pretty much like new with only 23,000 on the clock and one granny as a owner. I'm guess that lack of use may have cause this problem.
As the car has Suzuki dealer warranty, I will try and get them to do the work if possible.
Any help appreciated
Paul
Hertford
2005 Jimny VVT soft top
2002 Jimny Soft top - Sold
2007 Triumph Tiger 1050 - Sold
2011 Kawasaki W800
2002 Twin boys
2001 Kerry Blue Terrier - RIP
2012 GoldenDoodle
  • darthloachie
  • Visitor
  • Visitor
26 Jul 2012 12:31 #44945 by darthloachie
Replied by darthloachie on topic Re: Rear axle play
check the transfer box is not loose - this can give a clunk as you pull away if it is
26 Jul 2012 13:04 #44948 by kirkynut
Replied by kirkynut on topic Re: Rear axle play
Also nip up the radius arm bush bolts. I had this before and it was the crush tubes on the bushes moving in the mount as there is a little bit of movement on the bolt to the crush tube and it can make more noise than you'd anticipate.
26 Jul 2012 19:55 #44968 by pgatensuk
Replied by pgatensuk on topic Re: Rear axle play
Cheers chaps. I'll have another look in the morning.
I did check the radius arm bushes and couldn't detect any play, but will look again.
If it isn't radius arm bushes or transfer box mounts. What is there in the rear axle that could cause that play?
Laying under the car and rocking it (while in gear) the noise comes from the axle.
Cheers
Paul
Hertford
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
27 Jul 2012 21:51 #45003 by pgatensuk
After another dive under the car, I can confirm that is not mounts or bushes. It must be either the transfer box or rear axle.
Anyone got an idea what this could be?
Paul
Hertford
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
  • markyp2000
  • Visitor
  • Visitor
27 Jul 2012 22:12 #45004 by markyp2000
Replied by markyp2000 on topic Re: Rear axle play
put the parking brake on and turn the rear prop back and forth and see how much back lash the diff has
also while your there grab the rear wheel while its on the ground parking brake on and hold the wheel at 9 & 3 oclock and go back and forth to see how much the prop end of the diff moves up and down
check how tight your wheel nuts are
