Steering Slightly Off??
31 Jul 2012 16:17 #45141
by facade
Replied by facade on topic Re: Steering Slightly Off??
I've been and looked under the car. The panhard rod goes alongside the drag link, so as the axle moves up and down, it gets pushed sideways so as to minimise any effect on the steering. If you bend the panhard rod, it gets shorter, pulls the axle to the right, and you will have to steer to the right to straighten the wheels.
- Missile
11 Jul 2018 12:56 #194190
by Missile
Replied by Missile on topic Steering Slightly Off??
Hi sorry to resurrect an old thread. I'm having a similar problem. Exactly the same symptoms.
05 plate jimny. Standard. Road biased tyres. Bought it three months ago.
To drive straight I have to lightly steer to the right as described by the OP.
I have just had all the track rod ends replaced and the tracking done. Laser front alignment. New brakes all round. Haven't had time to go through the paperwork, but I'm assuming they got them aligned bang on. The arms don't appear to have been bent, the car doesn't seem like it's been offroaded in a previous life.
I'll check my tyre pressures tonight/profiles tonight.
What else could cause this?
Thanks
Thanks
11 Jul 2018 17:13 #194196
by facade
Replied by facade on topic Steering Slightly Off??
Possible causes now you have had the tracking done (and presumably all the joints & bushes were checked before they did it):
1) the drag link wasn't adjusted with the tracking, they are supposed to set the steering wheel central and then adjust both the drag link and tie rod (track rod) to get the wheels right
2) Someone took the steering wheel off and replaced it in the wrong place.
3) the back axle is out of alignment with the front.
I'd adjust the drag link and only worry if it changed again
- Missile
11 Jul 2018 18:50 #194200
by Missile
Many thanks Facade, especially after so many years.
I went ahead and checked tyre pressures and underneath. al the track rod ends are shiny and new + there's grip and spanner marks on the arms, so it's been done properly.
Tracking/alignment came with a diagram print out of before and after and the rear axle seams to be fine.
I would say option 1 or 2. I will query what the garage carried out tomorrow. I'm sure they would adjust it for free as its part of the job. I am wondering if its the steering wheel though as it does seem suspect. Everything else seems ok including springs.
Cheers for your help.
15 Jul 2018 20:25 #194305
by kirkynut
Replied by kirkynut on topic Steering Slightly Off??
They've probably just done the tracking with the steering wheel slightly off centre.
Go back and ask them to sort it.
Time to create page: 0.082 seconds
