seat belts
- JimnyX19
24 Jul 2012 06:37 #44796
by JimnyX19
seat belts was created by JimnyX19
Ive just taken my original seat belts out of my jimny as ive got harnesses on the seats now, but only problem is that my air bag light is staying on? Not 100% if the airbags on the belt mechanisms but need sonething to resolve this without putting the old belts back on , cheers guys for reading
24 Jul 2012 17:03 #44816
by kirkynut
Replied by kirkynut on topic Re: seat belts
You've removed the seatbelt pre-tensioners that pull the seatbelt tight and therefore you backin your seat. These are needed to ensure youare in the right place when the airbag goes off.
If you were not in the right place when the air bag goes off and it catches you under the chin, the fact it comes out at 200mph means it can snap and break your neck and you can die from that.
Now there is a problem with the airbag circuit, the airbag will be disabled as it doesn't know you are held back permanently by your harnesses.
This is an issue at MOT time now and I'm not sure how you'll get around this.
The MOT tester can see from the database that your car should have an airbag and the new MOT rules say it should be there are working.
This has buggered up alot of things for us petrolheads!!!
- markyp2000
24 Jul 2012 17:20 #44823
by markyp2000
Replied by markyp2000 on topic Re: seat belts
Kirkynut[/quote]
i thought this doesnt come in to the mot untill november?
just refit the front belt reals plug the wire in when it is moted thay should test the harness as long as the clip on the seat has been removed
Kirkynut[/quote]
- JimnyX19
24 Jul 2012 18:26 #44829
by JimnyX19
Replied by JimnyX19 on topic Re: seat belts
Cheers kirkynut and marky looks like the only solution is to put front belt reals back in and rewire but i havnt got the original belt click as i had one on the harnesses, and i have to get the new belts mot tested ? Always a hassle modifing things aint it
- Smoggy
24 Jul 2012 18:53 #44833
by Smoggy
Replied by Smoggy on topic Re: seat belts
What year is your Jimny? I wonder if this seatbelt pretensioner system is fitted to older pre 2001 cars?
24 Jul 2012 18:57 #44834
by kirkynut
just refit the front belt reals plug the wire in when it is moted thay should test the harness as long as the clip on the seat has been removed[/quote]
November or now, the problem remains. Bolting back in and reconnecting the seat belt plugs would solve it. Undo the battery before reconnecting though.
markyp2000 wrote: This is an issue at MOT time now and I'm not sure how you'll get around this.
Time to create page: 0.170 seconds
