Momentary grinding noise
  • beyondtheduero
14 years 3 months ago #44620 by beyondtheduero
Momentary grinding noise was created by beyondtheduero
I have only had the 2009 Jimny a few days, but I've noticed when I move away from a stationary position there is grinding noise for maybe one or two seconds. At no other time can I hear it and it seems when the car has been running a while it doesn't happen - for example pulling away from traffic lights.
It only happens after the car has been standing a while.
It appears to be coming from the underneath front part of the car.
Any ideas?
  • VAXXi
14 years 3 months ago #44659 by VAXXi
Replied by VAXXi on topic Re: Momentary grinding noise
If it's a short "bzzzt" happening each time after you start the engine and move the car, it might be the ABS system being enabled after the engine has been turned off.
  • beyondtheduero
14 years 3 months ago #44663 by beyondtheduero
Replied by beyondtheduero on topic Re: Momentary grinding noise
Thanks
I've found out what it is! I began to think because it only happens after the car has been standing and the grind sounds controlled and mechanical: not a raspy grating, that it maybe the 4WD engaging in some way, either the traction or differential... wasn't exactly sure what I was talking about!... so I drove it 60kms to the Suzuki worksop in Badajoz who immediately told me it was indeed the traction engaging, common to 4WDs...
So I'm not just relieved but happy I didn't panic and think the main drive bearings were shot...
14 years 3 months ago #44670 by robs5230
sticky vaccum hubs
standard jimny - for now
  • beyondtheduero
14 years 3 months ago #44672 by beyondtheduero
Huh...
So every time I start the car after it's been standing a while the vacuum hubs are switching from engaged 4WD to dis-engaged.
Why is that?... shouldn't they always be disengaged in 2WD until I decide to switch to them to 4WD.
Not sure how the system works but I guessed they would only disengage or engage with the driveshaft when you select 2WD or 4WD?
Time to create page: 0.073 seconds
