Odd noise
  • 2013gary
19 Jul 2012 10:39 #44522 by 2013gary
Odd noise was created by 2013gary
Hi everyone can I pick your brains?
My 2000(W) plate Jimny SOHC is making an odd noise when I first start it up from cold. I will try and upload a video tonight but to describe the noise it's very similar to that of a car with very low power steering fluid, but it is not continuous. It lasts for about a second and occurs every 2 or three seconds but only for a few minutes. If I ignore it and drive away the noise stops before I get to the end of the road and I do not hear it again until I start the Jimny again from cold.
I stuck my head under the bonnet and it appears to be coming from the alternator but it's difficult to tell so it may not be. There are no other signs of alternator problems such as dim lights etc. I checked the belt it's not too slack and there is no obvious damage to it.
Because of the nature of the sound I checked the power steering fluid and it was low (just above the minimum mark), so I topped this up. It made a big difference to the steering but hasn't fixed the noise.
Anyone have any ideas of what it could be? I've heard countless sounds on Youtube of cars starting up with bad alternator bearings and mine doesn't sound anyhting like this, but they might not all sound the same. I could change the alternator, but with no obvious signs of it not functioning properly it may be a waste of money. I can live with an occasional noise, but I'm worried it's a warning of a bigger problem to come...
Anyway, thanks for reading and I'll try and get some sound up tonight.
  • markyp2000
19 Jul 2012 12:19 #44524 by markyp2000
Replied by markyp2000 on topic Re: Odd noise
first check the tightness of the belts one may be lose or to tight or take the belts off and start it if no noise you no its to do with the belts then put one back on at a time if the noise is the when a belt is put on the id replace the belt let us no how you get on
  • 2013gary
19 Jul 2012 14:49 #44535 by 2013gary
Replied by 2013gary on topic Re: Odd noise
Thanks for that I'll give it a try.
I noticed that you're from Pembury I think I've seen you parked up during the week in Tonbridge a few times.
  • markyp2000
19 Jul 2012 15:01 #44536 by markyp2000
yer i work in tonbridge in one of the garages around where you see my car parked if you get stuck and your local i can alway help out
19 Jul 2012 16:46 #44539 by facade
Replied by facade on topic Re: Odd noise
Most likely it is just belt tension as said already.
My Nissan sounds like a handful of stones rattling round in and old can on the first start of the day if it has been raining. Soon goes as the belt dries out.
  • dirtydogz
19 Jul 2012 21:20 - 19 Jul 2012 21:24 #44565 by dirtydogz
Replied by dirtydogz on topic Re: Odd noise
On my SOHC, l had a noise which sounded like a dry alternator bearing, turn out to be a dry hard alternator belt and the fan + P.S. belt want much better so l replace both of them.
compare.ebay.co.uk/like/400279649332?var...&var=sbar&adtype=pla
Last edit: 19 Jul 2012 21:24 by dirtydogz.
Time to create page: 0.170 seconds
