Rear half shaft extraction
- Goat
14 Jul 2012 18:20 #44157
by Goat
Replied by Goat on topic Re: Rear half shaft extraction
Thanks for the replys everyone . Yeah I undid the 4 bolts and tried putting the wheel back on but it wouldn't budge.
- markyp2000
14 Jul 2012 18:46 #44158
by markyp2000
Replied by markyp2000 on topic Re: Rear half shaft extraction
is the back plate free its not stuck on with silicone or any other sealent if its not just tap it free with some wood and a hammer then put the wheel on and with out the drum and try spining it and hitting it with a rubber mallet or use the wheel as described as above
- Goat
14 Jul 2012 20:57 #44163
by Goat
Yes it was hanging free. I was hitting the wheel with a lump hammer as hard as I could and nothing was moving. Even put the hub on the wrong way round and belted that with a lump hammer.
- markyp2000
14 Jul 2012 21:14 - 14 Jul 2012 21:22 #44165
by markyp2000
does it have abs dont no if it makes a differece if the sensor is in or out take a look at renard38 jimny page 17 near the bottom has pics and videos
Last edit: 14 Jul 2012 21:22 by markyp2000.
14 Jul 2012 21:36 #44166
by mcjimny
Replied by mcjimny on topic Re: Rear half shaft extraction
If its never been off it will take a bit of work! Spray some wd40 around the end of the axle tube where the bearing sits, mine had corroded so much it was stuck the first time but i used the hitting the wheel with a hammer routine. I work my way round all the accessible parts of the wheel and it soon starts to move free. A deadblow hammer works well.
15 Jul 2012 12:09 - 15 Jul 2012 16:55 #44185
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Rear half shaft extraction
Nick take a look at this video + photos from Renard38
www.bigjimny.com/index.php/forum/20-fran...ents-de-roue-arriere
You will need to use a translator if you don't speak French.
2002 JLX Soft Top
Last edit: 15 Jul 2012 16:55 by dirtydogz.
Time to create page: 2.297 seconds
