Rear half shaft extraction
  • Goat
  • Visitor
  • Visitor
14 Jul 2012 08:19 - 14 Jul 2012 08:20 #44132 by Goat
Rear half shaft extraction was created by Goat
Went to change the rear wheel bearing yesterday but couldn't get the half shaft to come out. I think I need to invest in a slide hammer. Has anyone bought one recently, that would do the trick, that they would recommend?
Last edit: 14 Jul 2012 08:20 by Goat.
  • Paul4x4
  • Visitor
  • Visitor
14 Jul 2012 09:36 - 14 Jul 2012 10:36 #44137 by Paul4x4
Replied by Paul4x4 on topic Re: Rear half shaft extraction
I made a shaft pulling/installing tool myself many years ago when I bought my first SJ.
First I made a flange that would bolt on to the brake drum studs on the shaft, and then welded some 20" long pipe to the center of it, and to the other end of the pipe needed obviously something to be hit with a hammer, so I welded some strong enough flat steel there so I could hit on it with a hammer to pull the shaft out.
The beauty of this contraption is, that it also helps a lot when installing the shaft back into axle housing, because it's kind of an extension to the shaft itself, so its easy to slide the shaft in without the risk of damaging the oil seal!
If that made any sense? :laugh:
Last edit: 14 Jul 2012 10:36 by Paul4x4.
  • vitara_mad
  • Visitor
  • Visitor
14 Jul 2012 10:23 #44141 by vitara_mad
Replied by vitara_mad on topic Re: Rear half shaft extraction
No eBay APP ID and/or Cert ID defined in Kunena configurationi have 1 of these ive had it a couple of years now & is very good tool
14 Jul 2012 12:18 #44148 by facade
Try removing the drum. then putting the wheel back with the nuts half on (at least half) Then try snatching the wheel in and out a few dozen times.
  • Smoggy
  • Visitor
  • Visitor
14 Jul 2012 12:40 #44149 by Smoggy
Replied by Smoggy on topic Re: Rear half shaft extraction
Yeah ive got the same kit. Got it from machine mart, its a good comprehensive piece of kit but it still wouldnt pull my pitman arm off :angry:
  • markyp2000
  • Visitor
  • Visitor
14 Jul 2012 13:24 #44150 by markyp2000
Replied by markyp2000 on topic Re: Rear half shaft extraction
every one is asuming that the person nos what he is doingi may be wrong but i take it you have undone the 4 bolts on the back of the brake back plateand the brake pipes and as facade said should work just make shore its surported well as you dont want to pull it off it axle stands
Time to create page: 0.149 seconds
