axle filler plugs
13 Jul 2012 21:35 #44120 by robs5230
Replied by robs5230 on topic Re: axle filler plugs
on closer inspection there seems to be chemical metal used as a sealant :(
looks like i'll have to resort to the hex bar trick. i'll pick a bit up then weld it on when i get a dry day. cheers
standard jimny - for now
14 Jul 2012 12:15 #44147 by facade
Replied by facade on topic Re: axle filler plugs
Be careful you don't weld it to the casing :ohmy:
(That's the real reason I did mine off the car ;) )
14 Jul 2012 15:42 #44155 by robs5230
thanks , will do . when i pick the new ones up i will weld hex bar on before i refit.
Time to create page: 2.129 seconds
