axle filler plugs
12 Jul 2012 15:34 #44029 by robs5230
axle filler plugs was created by robs5230
i eventually called in to the stealers and ordered a pair of axle filler plugs. i also ordered " gaskets " that were shown on the parts diagram on their screen.
i have a couple of questions before i blow torch mine loose -
1 are the gaskets necessary every time the plugs are removed ?
2 on the diagram at the dealers another part was shown - any idea what this might be ? do i have to order something else ?
thanks rob
standard jimny - for now
12 Jul 2012 22:53 #44059 by facade
Replied by facade on topic Re: axle filler plugs
1) no, re use the old ones unless they are damaged, they are only a sealing washer, and the oil doesn't come up that high except by splashing. In The Olden Days I used to anneal any copper washers that I took off things by heating them up with a blowlamp. Nowadays I don't bother, and they still don't leak.
2) not the faintest idea, need to see a picture.
The filler plugs usually come out fairly easily with a chisel to knock them round anticlockwise, and don't need heat.
The drain plugs need a smear of sealant on the threads when they go back. Anything oil proof will do.
13 Jul 2012 05:36 #44064 by robs5230
Replied by robs5230 on topic Re: axle filler plugs
oh no they won't :)
can't imagine when they were last undone . not shifting at all . chisel not budging them and i even bought a 10mm square tool which also will not move 'em . any ideas ??
thanks for the reply
  • Smoggy
  • Visitor
  • Visitor
13 Jul 2012 06:06 #44066 by Smoggy
Replied by Smoggy on topic Re: axle filler plugs
facade wrote: 1) no, re use the old ones unless they are damaged, they are only a sealing washer, and the oil doesn't come up that high except by splashing. In The Olden Days I used to anneal any copper washers that I took off things by heating them up with a blowlamp. Nowadays I don't bother, and they still don't leak.
Yeah I now realise this after not putting any on my gearbox drain plug. And now its dripping!
13 Jul 2012 16:21 #44095 by facade
The usual suggestion on here is to get a big bolt or piece of hexagon bar, file a slightly over 10mm square on the end, tap into the hole and weld it in, then undo it quickly whilst it is still hot.
Mine was tight enough to turn the square hole round, but chiselled out with a couple of taps, then I welded the hexagon in place off the car.
13 Jul 2012 19:08 #44110 by j999pre
Replied by j999pre on topic Re: axle filler plugs
You could try done big mole grips to grip the edges then a whack with a bfh!
Grey pick up Jimny
Time to create page: 0.157 seconds
