Where to attach a vacuum gauge?
  • vegetablejoe
12 Jul 2012 01:50 #44003 by vegetablejoe
Where to attach a vacuum gauge? was created by vegetablejoe
Hi!
I've been quietly reading through the forum (ok, lurking) and have decided to join up as I need to ask a question and have not seen the answer anywhere yet.
I own a 2012 Jimny (actually a Dec 2011 model, delivered CBU from Japan), and would like to get more than my current 21-23 mpg fuel consumption (city driving). To this end I bought a Veglia Borletti Vacuum Gauge. But when I looke under the hood at the carburator and air intake fittings, I couldn't determine where to install the gauge's hose.
Has anyone installed a vacuum gauge and can point out where exactly I should do this? I'm not mechanically inclined, so a picture with an explanation would certainly go a long way.
Thank you in advance!
Jaime
Manila
12 Jul 2012 22:36 #44055 by Johnniehec
I thought I, reply as no one else has, I don't think this is a common mod inthe UK, I've never heard of it. Hopefully someone else has.
Cheers,
John
12 Jul 2012 22:44 #44056 by facade
Unless the 2011 is radically different to early models, there should be a rubber pipe about 8mm diameter that goes from the inlet manifold to the vacuum solenoids under the battery that operate the hubs. Tee into this pipe.
  • vegetablejoe
13 Jul 2012 10:06 #44072 by vegetablejoe
Replied by vegetablejoe on topic Re: Where to attach a vacuum gauge?
Thanks! Will have a look over the weekend and see if it's something I can DIY.
  • markyp2000
13 Jul 2012 10:12 #44074 by markyp2000
Replied by markyp2000 on topic Re: Where to attach a vacuum gauge?
Johnniehec wrote: I thought I, reply as no one else has, I don't think this is a common mod inthe UK, I've never heard of it. Hopefully someone else has.
Cheers,
John
this is what most people put on turbo cars boost/vacuum gauge as long as it goes after the throttle butterfly it will be ok failing that read the instructions
13 Jul 2012 16:36 #44098 by facade
Here is where I mean, on my X reg, the blue thing is a one way valve, so the gauge must go into the pipe that connects to the spigot on the manifold.
Time to create page: 0.106 seconds
