Removing steering box?
- Smoggy
08 Jul 2012 13:47 - 08 Jul 2012 13:48 #43704
by Smoggy
Removing steering box? was created by Smoggy
I need to get the steering box into my vice to remove the pitman arm, but im not sure how to disconnect the high pressure hose assembly from the car. The hose connections appear to be some kind of special fitting linking the flexi pipe to the solid pipe sections.
Is there an easy method for doing this please?
Last edit: 08 Jul 2012 13:48 by Smoggy.
- markyp2000
08 Jul 2012 14:00 #43706
by markyp2000
Replied by markyp2000 on topic Re: Removing steering box?
remove the rad just to get more room then just undo the bolt that goes through the thick pipe on the right as you look down on it and the other on just take the hose clip off and pull the pipe off
- Smoggy
08 Jul 2012 17:48 #43725
by Smoggy
Replied by Smoggy on topic Re: Removing steering box?
Yeah sorted that just like you said Mark.
Next big task was to get the pitman arm bolt off, ready for the new drop arm to go with my lift. Got the really tight bolt off with easing oil, heat and the help of my windy gun - eventuallly.
Then I found the pitman arm was welded onto the box splines, despite heat and easing oil and the help of my slide hammer attached to a puller it still wouldnt budge
So ive left it overnight steeped in plusgas.
- markyp2000
08 Jul 2012 18:15 #43726
by markyp2000
try some pipe frezze from a plumers center and try and freeze the splines so it shrinks just an idear let us no how you get on
- aniesigh
08 Jul 2012 18:34 #43730
by aniesigh
Replied by aniesigh on topic Re: Removing steering box?
Are you re-using the pitman? try welding all around it on round part of the pitman that has the splines on the inside, then when its real hot try smacking it off
- markyp2000
08 Jul 2012 18:49 #43733
by markyp2000
NO he says he has a new one to go on with hes lift
