Rocklobster fitting/propshafts
06 Jul 2012 20:46 #43623 by j999pre
Finally fitted my rocklobster :)
Couple of questions for you.
The front SJ prop thats used as a rear looks very compressed. I probably have about a flange widths play left in compression is this ok?
Secondly how have people sealed up the sj speedo take off? Or does it even need doing?
Thanks
Grey pick up Jimny
  • suzuki jimny fella
  • Visitor
  • Visitor
06 Jul 2012 22:39 #43637 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: Rocklobster fitting/propshafts
i stuck some grease in there and when i jet wash her i put more in the hole lol as check for damage on etc
  • p1ngu32
  • Visitor
  • Visitor
09 Jul 2012 21:42 #43851 by p1ngu32
Replied by p1ngu32 on topic Re: Rocklobster fitting/propshafts
I have a little bit more than that on my prop with a 3" lift, to seal up the speedo take off i used a 15mm yorkshire stop end which you will get at any diy store. its a perfect fit but i glued it in place to make sure
10 Jul 2012 08:35 #43858 by j999pre
I'm off to the diy shop after seeing that. Thanks
Mine has a 2" lift so maybe I need to think about going bigger to get a little more free play.
Grey pick up Jimny
10 Jul 2012 12:22 #43864 by Johnniehec
Neat job P1ngu32, how are you doing? There's a BORDC trial at Lumsden on the 22nd, I'll not be there cos we're away on hols but it's not far from you.
Cheers,
John.
  • p1ngu32
  • Visitor
  • Visitor
10 Jul 2012 17:20 #43887 by p1ngu32
Cheers john, i'm good, won't be getting to any trials this year unfortunately, we have litterally just had our first baby so thats put things on hold for a wee while at least, some thing to think about for the future though!
you might be ok with the freeplay that you have, the axles tend to twist one way or the other so you would only ever be compressing one spring fully, you would possibly have to jump some thing with the jimny to compress both sides of the suspension enough to bottom out the prop.
Richard.
Time to create page: 0.157 seconds
