Problems fitting ORA bumpers
  • Smoggy
06 Jul 2012 18:38 - 06 Jul 2012 18:45 #43612 by Smoggy
Problems fitting ORA bumpers was created by Smoggy
Im having a nightmare job with my front bumper fitting. When I removed the old bumper I realised the car has previously had a bit of a bump. The crumple legs were slightly bent (mostly on passenger side). I thought it would be okay because I was cutting these off anyway per the ORA instructions.
But the remainder of the chassis leg is still not great.
There is a weld about 8'' back (just behind where the body mount leg attaches to the chassis leg).
I was thinking of cutting the chassis leg here and reattaching the body mount leg and slam panel to a newly fabricated leg.
Any ideas anyone?
Last edit: 06 Jul 2012 18:45 by Smoggy.
  • X-Eng Simon
06 Jul 2012 20:00 - 06 Jul 2012 20:00 #43613 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Problems fitting ORA bumpers
Mine was similarly bad - and had taken an impact in the middle which had crumpled the cross member. I cut this out and sleeved the original chassis rails with 3mm plate before replacing the cross member with CDS tube.
In your case, I'd be inclined to do similar - perhaps replacing the cross member with box section.
Only cut the minimum off the ends of the chassis legs you need to. Then you have something solid to attach the bumper to.
Sleeving the rails you have a better chance of getting a decent strength weld (and enough length of it) than a butt weld of a new bit of box on to the chassis rail end. In addition to welding the end, cut some holes in the sleeves & plug-weld to the original chassis leg.
Si
Last edit: 06 Jul 2012 20:00 by X-Eng Simon.
  • Smoggy
06 Jul 2012 20:16 - 06 Jul 2012 20:19 #43615 by Smoggy
Replied by Smoggy on topic Re: Problems fitting ORA bumpers
Thats great Si Thanks.
I will replace the crossmember with some 3mm box and remove the body mount legs, then sleeve 3mm plate/box over the existing leg and plug weld through to the legs. Then re-attach the body mount.
Just as you suggest :cheer:
I was gonna remove the front antiroll bar anyway! If they ask for one at MOT time then il make sure the cross member box replacementis positioned accordingly.
Thats why youre the expert, grateful guys like you on here.
Last edit: 06 Jul 2012 20:19 by Smoggy.
  • Smoggy
14 Jul 2012 20:00 - 14 Jul 2012 21:03 #44160 by Smoggy
Well I've sleeved the chassis legs and welded in a 100mm x 50mm steel 3mm crossmember. Please feel free to add your comments on my dubious welding skills (I gratefully welcome your comments/criticism on whether you believe the welds will withstand the rigours of winching jim through the mud).
Some of the welds look good to me - others less so :unsure:
Driver chassis leg outside:
Inside:
Passenger chassis leg outside:
Inside:
Inside/top:
Front View:
Last edit: 14 Jul 2012 21:03 by Smoggy.
  • Smoggy
14 Jul 2012 20:06 #44161 by Smoggy
Cant load pics - keeps coming up fatal error contact site owner?
  • markyp2000
14 Jul 2012 20:26 #44162 by markyp2000
Replied by markyp2000 on topic Re: Problems fitting ORA bumpers
whats the pixal size may be to big
Time to create page: 0.241 seconds
