fitting spring spacer to cure the jimny lean help
- Thank you received: 77
01 Jul 2012 08:45 - 01 Jul 2012 08:51 #43289
by robs5230
standard jimny - for now
fitting spring spacer to cure the jimny lean help was created by robs5230
feel a bit of a dick cos i've been here before. tried to do this last week and struggled. couldn't get the axle to drop far enough to get the spring out let alone fit a spacer so i need to ask more questions.
1 does the whole front have to be jacked up ?
2 should both front lower shock bolts be removed ?
3 should both front wheels be off
4 as i only have 1 trolley jack can i jack in the centre of the axle ?
when i tried last week i only jacked 1 side and only removed 1 shock bolt.
thanks, rob
thanks, rob
Last edit: 01 Jul 2012 08:51 by robs5230.
- reaper
01 Jul 2012 09:23 #43290
by reaper
Replied by reaper on topic Re: fitting spring spacer to cure the jimny lean help
You will probably strugle without extended brake line and a set of spring compressor
- vitara_mad
01 Jul 2012 09:29 #43292
by vitara_mad
Replied by vitara_mad on topic Re: fitting spring spacer to cure the jimny lean help
if you jack front up & put axel stands under chassis then jack axel to compress shocks a bit & take bottom bolts out you can get spring & out & spacers in easy but also if your brake hoses are not long enough you will need to remove calipers too
01 Jul 2012 10:58 #43293
by robs5230
Replied by robs5230 on topic Re: fitting spring spacer to cure the jimny lean help
done it ! enough play to get the springs out but with the spacer too tight to go back in. nipped the spring up with ratchet straps to get it back in. all sitting square and proud. pissed no more
well the jimny anyhow ! cheers boys
01 Jul 2012 11:29 #43294
by robs5230
what a difference !! just took it for a spin around the lanes. no more do i feel i'm going to fall out of the drivers window and the suspension works much better. less transmission noise. feels very well planted all round. i would recommend this mod to anyone with any sort of lean for an instant cure.
big thanks to all who gave help and advice
- stevedumptruck63
01 Jul 2012 15:46 - 01 Jul 2012 15:46 #43313
by stevedumptruck63
hi what thickness spacer did you fit? and did you fit just 1 to the drivers side front? thanks in advance. steve
Replied by stevedumptruck63 on topic Re: fitting spring spacer to cure the jimny lean help
robs5230 wrote: what a difference !! just took it for a spin around the lanes. no more do i feel i'm going to fall out of the drivers window and the suspension works much better. less transmission noise. feels very well planted all round. i would recommend this mod to anyone with any sort of lean for an instant cure.
Last edit: 01 Jul 2012 15:46 by stevedumptruck63.
Time to create page: 0.134 seconds
