spring compressor recommendations
  • markyp2000
01 Jul 2012 08:00 #43279 by markyp2000
Re: spring compressor recommendations was created by markyp2000
no you dont i had a 3" lift all i done was unbolt the o/s/f caliper unbolt lower shock mount and the anti roll bar if its fitted remove sprong fit 2" spacer pull axal down refit spring and jack up axal and bolt back together
01 Jul 2012 08:17 #43281 by robs5230
tried this last weekend and struggled. axle didn't want to come down enough and there was still far too much tension in the spring. i only undid the shock on the side i was doing (drivers) , i have extended brake lines so caliper is ok.
i did buy the jimny modded already so in truth i have no real idea of the lift on it. the front springs do however seem to have a real bow due to the axle tilting. the shocks and springs do look and feel old and tired
standard jimny - for now
01 Jul 2012 08:22 #43284 by robs5230
this is going to sound stupid but should both sides of the front be raised to do this ?? ( only raised drivers ). do you jack up under the diff to get the whole front up at once ? cheers
  • markyp2000
01 Jul 2012 08:35 #43286 by markyp2000
Replied by markyp2000 on topic Re: spring compressor recommendations
jack it up very high on the axle then use axel stands on the chassis and yes id lower both sides
