swivel joint seals - where to buy new set
- jonplace
18 Aug 2010 08:05 #4286
by jonplace
swivel joint seals - where to buy new set was created by jonplace
wheres the best place to get a new set of swivel joint seals ?
dealers or does anyone know of an alternative
cheers
cheers
18 Aug 2010 08:06 #4287
Replied by mlines on topic Re:swivel joint seals - where to buy new set
ebay - I don't do them as I cannot get them as cheap as they go on ebay.
- jonplace
18 Aug 2010 08:10 #4288
by jonplace
Replied by jonplace on topic Re:swivel joint seals - where to buy new set
ok thanks martin
i'm going to try and clean them up again but done this a couple of times now and still get a bit gunge and leakage coming through
going to check the kingpins again and replace if necessary, ordered a new set so i have them if they're needed.
if i could get a cheap (ish) set of seals i'd do those aswell.
will keep an eye out on ebay
cheers
cheers
- mcjimny
18 Aug 2010 12:52 #4289
by mcjimny
Replied by mcjimny on topic Re:swivel joint seals - where to buy new set
I recently bought some off ebay, theres a main stealer on there
cgi.ebay.co.uk/Suzuki-Jimny-Swivel-Joint...Vehicles_CarParts_SM
Works out the cheapest way to do it, buy the bearings off martin then the seals off ebay.
They didn't come in time for me to change them though so they'll get done the next time, apparently they didn't get the email from ebay so they weren't sent out until i contacted them.
19 Aug 2010 07:31 #4301
by kirkynut
Replied by kirkynut on topic Re:swivel joint seals - where to buy new set
I would say eBay too but if you can't find them I could dig out the part number for you to go to a dealer and spend your port savings.
19 Aug 2010 10:27 #4306
by facade
Replied by facade on topic Re:swivel joint seals - where to buy new set
mcjimny wrote:
They can be done at any time with the hub assembled, the official manual says to cut the seal to get it on, and put the cut at the top.
There are some on eBay right now £25.98 each :ohmy:
