manual hubs - no 4wd green light ??
25 Jun 2012 18:43 #42912 by robs5230
thanks for all the advice chaps
standard jimny - for now
  • Cabriolet
  • Visitor
  • Visitor
25 Jun 2012 20:27 #42920 by Cabriolet
Replied by Cabriolet on topic Re: manual hubs - no 4wd green light ??
I am a fan of the vacuum hubs, if they are working correctly they are just the same as manual hubs, but without the manual intervention of getting out the car in the mud and thewind and rain to operate them. Properly serviced and maintained there is no reason for them to fail, and if vacuum lines do somehow get damaged, they can be manually over-ridden to get you home with a single socket and a screwdriver.
Not having studied the electrical side of the system, I guess to give the ability to drop the drive to the front wheels when in 4L. For situations when the low gearing is needed, but the locked transfer box is not. To manually over ride the hub solenoids do you just need to interupt the 12v to the solenoid? I suppose I should just go and give it a try. Then that would give you back the only benefit that manual free wheel hubs have over the vacuum operated ones.
Time to create page: 0.171 seconds
