manual hubs - no 4wd green light ??
- Thank you received: 77
24 Jun 2012 20:37 #42846
by robs5230
standard jimny - for now
manual hubs - no 4wd green light ?? was created by robs5230
just fitted aisin manual hubs. tested and working but no green 4wd light on dash. is this right ??
- markyp2000
- Visitor
24 Jun 2012 22:30 #42863
by markyp2000
Replied by markyp2000 on topic Re: manual hubs - no 4wd green light ??
i think it should flash indicating a fault as the hubs are not there that did you do the the vacuum pipes to the hubs
24 Jun 2012 23:30 #42869
by mcjimny
Replied by mcjimny on topic Re: manual hubs - no 4wd green light ??
Mine sometimes takes a short distance to come on flashing. All its doing is telling you there's vacuum or not and engaging the auto hubs. As long as you know the manual hubs are working when you select 4wd all should be well, the light doesn't relate to the transfer box and physically engaging 4wd.
Despite some sticking with the auto hubs and successfully repairing them, fitting the manual hubs is the best thing i've done.
25 Jun 2012 08:12 #42873
by kirkynut
Replied by kirkynut on topic Re: manual hubs - no 4wd green light ??
My light still comes on as solid green and should flash if there is no vacuum.
Check the wires to the switch on the trasfer box, although it would be a spooky co-incidence that one has fallen off just as you change the hubs!
25 Jun 2012 09:47 #42880
by robs5230
Replied by robs5230 on topic Re: manual hubs - no 4wd green light ??
yeah will do thanks.
25 Jun 2012 17:14 #42899
by facade
Replied by facade on topic Re: manual hubs - no 4wd green light ??
If you look under the battery=, there are 2 vacuum solenoid valve thingies, loads of bits of rubber pipe, and a switch with 2 wires on a connector.
Join the 2 wires.
Cap the rubber pipe fitting on top of the manifold to stop any vacuum leaks, sorted.
Or, just bung small bolts in the 2 rubber pipes that go from the solenoids down to the axle and the switch will work as it did before..
Join the 2 wires.
Time to create page: 0.143 seconds
