panhard rods
17 Aug 2010 15:29 #4270
by facade
Replied by facade on topic Re:panhard rods
Should do, if the rod is too short it will pull the axle over and try to pull the car down.
I would disconnect the back, and adjust the front 'till the bolts are lined with the holes. then fit the front and adjust the rear.
17 Aug 2010 18:01 #4279
Replied by mlines on topic Re:panhard rods
I was told to put the car on a level surface with the panhard rods disconnected. Rock the car a bit to make sure the suspension settles. Then if you have adjustable rods simply adjust them so you can put the bolts in them and tighten them up.
If you have non-adjustable ones you then need to cut them and weld them so the holes line up
