panhard rods
- oxford_bloke
16 Aug 2010 19:40 #4256
by oxford_bloke
panhard rods was created by oxford_bloke
hi all,
I am in the process of fitting my 4.5inch lift from ORA and have got round to fitting the panhard rods. so can anybody tell me what size they should be if not how to get the to the right size.
Cheers guys and many thanks
Tom
Tom
- darthloachie
16 Aug 2010 19:49 #4258
by darthloachie
Replied by darthloachie on topic Re:panhard rods
Why don't you give Rob at ORA a ring, or he has a forum attached to his website that is worth a look
16 Aug 2010 20:11 #4261
by facade
Replied by facade on topic Re:panhard rods
When you find the length, you can get adjustable rods, or splice a piece in yours, welding is ok as long as it is done properly and doesn't reduce the strength of the component.
Me, I'd just hacksaw across the rod now, centre the axle, measure the gap and weld a piece in, most likely turn a plug to keep the two parts true, and tack it in place on the car to save aligning the two ends
Just make sure the repair is strong enough, you don't want it to come apart half way up Kilimanjaro :blink:
- oxford_bloke
16 Aug 2010 20:21 #4262
by oxford_bloke
Replied by oxford_bloke on topic Re:panhard rods
I have adjustable HD Panhard rods with came with the kit. which look like they have an extra 2 inches (ish) available for adjustment 1 inch on either end where the rose joints screw in.
Cheers guys
Tom
Cheers guys
Tom
16 Aug 2010 20:44 #4264
by facade
They should be opposite threads, if so, dead easy, turn the tube until the axle is centralised.
Likely the springs will centralise it, so you could just adjust it until the eye bolts slide in and out standing on level ground.
- oxford_bloke
16 Aug 2010 20:47 #4265
by oxford_bloke
cheers for that i'm asuming then that this will stop the body from looking lop sided to?
cheers
tom
cheers
tom
Time to create page: 0.157 seconds
